Vcarve pro generating redundant M6’s that confuse Gsender TLS
If this is a redundant topic or posted in the wrong forum - my apologies; however, I have not found discussions related to a problem I have struggled with for almost a year.
I do not profess to be a rocket scientist (nor a gCode expert) but I have struggled to get a TLS to work on an Altmil with tool paths combined in VCarve Pro. The g-code created when saving combined tool paths was resulting in multiple and redundant M6 commands. gSender then processed these as redundant actions (causing a vicious loop of tool measurements). I had/have notes in the tool definitions (in VCarve) that result in VCarve creating redundant M6 commands.
Maybe not the ideal solution, but by deleting the tool notes in vCarve the resulting g-code is clean and runs as expected.
Maybe posting the gcode file would help to find a solution.
Hey yes this was discussed here: Tool Length Sensor Availability - #9 by Davey we have an updated post processor that should avoid that bug.
Excellent! Thank you. I should now be able to leave the notes in my tool definations.
