Hi there - I have a MKII 30x30 with the vortex, regular long board. I have the latest version of gsender, which I upgraded a while ago. Pretty sure its 1.5.6.
Prior to this version, everything worked great with the Vortex, I just haven’t used it in a bit. Well, now that I’m back at it, I’m trying to run a job. I have VCarve Pro, I have not changed the install and have the vortex options installed for a rotary job, etc. A job is created, and the gcode looks reasonable in that its move XZ and A. When I go to run this job, however, A is stepping way more than it should. Instead of 360 steps per rotation, its like 35 (according to the A position after moving the vortex 1 turn). Surfacing (turning a piece from square to round) works fine. The job, when its doing just a round portion, revolves many times rather than 1. The result of the job is essentially a round piece of wood.
I verified I was connected via GRBL and not the HAL driver - saw that in another post here. What did I miss or need to do to fix this problem? If I manually enter G1A360 I get and unsupported message and when I ran the jobs on the machine it looked to be getting Y moves on the console - is that normal?
It’s probably something I missed with this new version of GSender. This is with open loop steppers.
Thanks for the reply. I did verify that was the value in the settings.
When using the control buttons, what value should A have after one full rotation of jog? I get 35.
@Norm258 I’ll be in the shop later today and will check. My values may not compare to yours, as I am using the SLB with a closed loop motor on my Vortex.
@Norm258 I just rotated the Vortex using the jog buttons. As I expected, a full turn of the chuck reads as 360° in the GUI readout. Notwithstanding our different setups, I’m pretty sure that yours should read the same. Either someone here or Sienci may prove me wrong, though.
@Norm258 No, when you move the rotary slider to ON, it will change the Y value to the A value. You will see a pop-up screen saying that. When you revert to “flat” work, it will reverse the process.
