I have the Altmill MK2 my vortex was working properly. I carved several different things. I let it sit for about a month and went to use it and it will not spin. It doesn’t energize at start up.
I can energize the motor in the configuration settings but when I go to rotate it, it does nothing. I swapped A axis with the Z axis to test the motor and cables and the rotary will work fine. When I hook my Z motor to the A axis port the motor will not move nor will it energize.
I would assume the issue is because I did update gsender version while not using the vortex. What should my settings be for the rotary?
Thanks for all the help.
