Well opps... gsender will not come back on line
Ever since I enabled wireless control, the software will not fire up, or at least it does not look to be doing this, even after I reinstalled gsender… Any thoughts
Well, I figured this out… Note to self: do not click that button.
@mborgardt Another lesson learned and a solution for all. Please post what button you shouldn’t have pushed.
The Wireless Control tab for mobile. right now it does not seem to work or at least for me.
I had to rename the config file ( gsender-0.5.6.json) along with (Sender_rc) file then restart to make a new config file.
I will wait to see what the say but it did work some time ago but not now…
Hope this helps anyone.
@mborgardt for the most parts we’ve tried to introduce checks so that if the wireless mode fails then it deactivates and reopens gSender instead of not opening at all, so it sounds like however you set it up it somehow failed and wasn’t caught. Would there be any way for you to try again and share your settings before restarting so that we could get a bit more insight towards fixing it? You could backup all your settings beforehand so that nothing is lost on this next attempt. If you’re also not comfortable doing it again then that’s ok too.
