When leaving rotary mode gsender not going to back the default
Dear all,
A similar issue was reported last year but the topic is already closed. I‘m on gsender 1.5.6. I have default for y-axis 400 steps / mm. When I activate rotary mode this value is overwritten as expected. In my case 17.78 steps /mm.
When I switch off rotary mode y-axis is not reverting to 400 steps but 200 steps. Is there any additional setting I need to do to store the correct value for y-axis. I applied settings (written to eprom) was confirmed. I‘m using a diy cnc with grbl.
Is this a bug in 1.5.6 or am I doing something wrong?
Thank you very much,
Thomas
Hi @Mingarer, since we’re gearing up for a new gSender Main release I’m digging through older topics that fell through the cracks to see if the problems are now resolved on new gSender or gSender Edge versions, or if they still are occurring and if so then we’d like to fix them up promptly if we can.
If you can give any response in the next week or so it’d be greatly appreciated :+1:
Thanks for your feedback. We found the issue, and there will be a fix for it in the next release.
