I am having issues where I go and open a file in gsender that I have used in the past without an issue but now I get it set up and zero everything but when I hit run the Z axis drops 2mm into the cut and travels to the start point only to lift back up and start cutting. It is also finishing a cut and then diving 2mm down and traveling across then material.
I am using the latest Fusion 360 and the latest Gsender. Not sure what is happening, the same file two days ago worked fine. This has happened to multiple files.
I have the long mill mk1 30x12. The only change is that gender updated recently, I had only cut maybe 6 things prior to the update as I just got the machine up and going.
I am still having issues. I have reinstalled Gsender but it did not change. When I run a simulation in Fusion360 I am not seeing the tool drop down before and after. Could it just be that I have a setting wrong somewhere?
