X- Axis Inaccuracy
Just completed 48 x 30 machine assembly, updated Vcarve Pro and Gsender to required parameters.
Using 24 x 24 board attempted t0 carve 2" circle in center to test for accuracy.
Result was Y axis height correct, X axis 4" left of center and Oval carved instead of circle.
Machine is dead square and adjusted to specs.
Hello @mwbeard1957 and welcome to the forum. You mention the Y dimension is correct but didn’t say what the X dimension of the oval is.
Is the oval longer along the Y axis like the X axis is not moving enough? If so you may want to check out this post by Sienci. They mention a couple of things to check with the X axis if that’s the issue.
When I assembled my MK1 30x30 I didn’t get the motor to lead screw coupler tight enough and the X axis would slip under load.
Got it this morning, did a burn to the system board again this morning and this time it seems to have taken hold. Works like a charm now. Thanks!
I responded via email I assume on the day you asked this question, if you didn’t receive it please let me know.
