X axis screw Bouncing
Hello Everyone. I am new to the Longmill MK 2.5 just bought it a month ago and just finished setting it up with the upgraded closed motor upgrade. I had been waiting for the upgrade to finish putting it together. Well finally received the upgrade today. Well enough, with the history and on with the problem. When I move the spindle on the x axis the screw vibrates violently. How do I fix this? Thanks in advance.
Welcome to the group David!
It’s possible that the anti-backlash block is too tight or a little crooked. You might try to loosen the mounting bolts for the block enough so it can move and jogging slowly back and forth a couple inches and then tighten them back up. I have the old kind without the spring but I think the crooked thing could happen with either kind.
Ty for the reply. I have fixed this issue wasn’t able to delete the post.
@dpazynski Please post your solution. It will help others going forward.
