Y Axis not moving correct distance
Just set up my new Longmill MK3 30 x 30. The x and z axes are moving as expected. The Y axis is only moving about 25% of the expected distance. When I jog in rapid mode, it moves 5mm instead of 20mm. When homed, the machine thinks it moves the full 830mm but is only a quarter of that. I’ve triple checked the DIP switches on the Y axis motors. All cable connections feel secure. I released one of the Y axis rails from the work table to see if they were misaligned. Nothing sounds off, it’s just not moving as far as expected. Im using the SBL-Lite and g sender software. Ive reset the machine defaults in g sender and switched back and forth between machine selections. I’d appreciate any thoughts! Thank you!
@JMac007 Quadruple check the switches?
1-OFF 2-OFF 3-ON 4-ON 5-ON
There is a calibration routine in gSender but I’m not sure it’s meant for movement that is 25% off. It really sounds like a dip switch issue. The table below shows the steps/mm
I would double-check that the firmware settings are set properly for the Mk3. I’m not sure what those are though. I would assume they get set properly when you tell gSender your machine is a Mk3. I think it is $101=80 if I correlate the dip switch values above with the table below.
Microstepping Dip Switch Position Switch #1 Switch #2 Switch #3 Switch #4 Switch #5 Firmware Step/mm
1/2 OFF ON ON ON ON 40
1/4 OFF OFF ON ON ON 80
1/8 OFF ON OFF ON ON 160
1/16 OFF OFF OFF ON ON 320
1/32 OFF ON ON OFF ON 720
1/64 OFF OFF ON OFF ON 1440
1/128 OFF ON OFF OFF ON 2880
1/256 OFF OFF OFF OFF ON 5760
The only other thing I would try is uncoupling the two coupling nuts for the Y axis to see if both motors actually turn.
Wow! Thank you for your incredibly thoughtful and thorough reply. That is so appreciated!
Your first suggestion was the right one. The folks from sienci asked for photos of the dip switches. Photos required that I put some good light on the dip switches. That let me see the on direction! Since the y axis motors are “upside down” compared to the x and z axis motors, 1-down 2-down 3-up 4-up 5-up was wrong. When I fixed the dip switches, it worked perfectly.
Thank you again!
@JMac007 Since this issue is resolved, I’ll close the topic. Have fun. Be sure to post your projects.
