Z 3mm above Initial Zero after using tool change
I use 1.4.12 with a fixed tool setter and after changing the tool the z is about 3mm above initial tool after. and no it’s not the missing material, the actual 10mm of selected cut under the model top is only 7mm
i don’t get it, why?
@iuliancalin can you give a bit more context about your setup and steps you’re following? Also perhaps re-trying this on a newer gSender version might be worthwhile just so that we can confirm the issue still exists and needs fixing
Stuff changed since then, it’s been awhile, I believe it’s fixed now, I don’t really know, I haven’t done any major jobs or used my CNC lately :cry:
Wait, edit that, as I said, it’s been awhile, but I believe it was my Z axis motor that was set too fast, acceleration and speed, and it was acting weird, sometimes just give up. I don’t really remember exactly, but it didn’t happen anymore.
I will try to make something in the coming week so , Fingers crossed :crossed_fingers:
