I’ve ran into an issue with travel limit exceeded error on the z-axis. I have limit sensors for homing that axis and everything works as it should. The soft limits in the full axis travel, also work as they should as I can jog to get to them. When I try and rapid jog that axis down from home, I get the exceed travel limit error. If jog is released I can continue to single jog the axis down.
@wgantt I had a similar issue but with the Y axis. I’m not sure if it’s the same behaviour as you but increasing the “Homing switch pull-off distance” from 1.5mm to 2mm resolved the issue for me.
Try that first and if doesn’t work, someone may have other suggestions.
Which error or alarm are you getting? FYI, there’s a difference between the Alarm codes and Error codes of the same number. So make sure you specify Alarm or Error.
