Machine: Longmill MK2 48x30 with SLB and Makita router
The job is vcarving text for 72 coasters over an hour or so, and by the end the text is nearly double the depth as the first coasters. For future runs, I ended up dividing the “rows” into separate files in VCarve and re-zeroed each time but would like to figure it out for the next batch.
For testing, I used a block to zero my Z off of the spoilboard and then with the router off, I let the complete job cut in mid air. When I put the router back at XYZ0, I had to raise Z approximately .025 inches to clear the block. Not a lot, but makes a big difference with a 90 degree V bit.
Things I have tried:
- Checked Z-Axis coupler and Spring-loaded Anti Backlash nut
- Toggling Independent Motor Holding via $37 in the firmware with $212 at the default of 35
- Ran the Z-Axis movement tuning with setup blocks (stayed at the default of 800)
I’ll run through the movement tuning again just to be sure, but was hoping someone else may have some suggestions to check when I’m there.
Thanks
