ATC using the Code segment
Hello,
Trying to figure out a ATC on a shapeoko 5 using the Before / After M6 code blocks.
When running %requestedTool = Number([tool]) I am always 1 tool behind.
If I do the following GCode
M6 T1
Requested Tool = T1
M6 T2
Requested Tool = T1
M6 T3
Requested Tool = T2
I assume [Tool] is the wrong thing to ask but I dont know what else to put in there.
Thanks
Summary
This text will be hidden
@ganfan Does this help at all?
I have tried every variation of
T# M6
M6 T#
T#
M6
On occasion it seems to work well with out issues and I cannot tell why.
This is my current macro which sits entirely in the After M6 area. On the last test it just went back to T5 every time when I ran the GCode for all 3 M6’s
; ATC - COMPLETE M6
; Use in gSender AFTER M6 area.
; global.atc.currentTool = physical tool currently in spindle
; global.atc.requestedTool = requested M6 tool
; New gSender session starts with no known tool loaded.
; Deposit dwell = 0.5 sec
; Pickup dwell = 3 sec
; CONSTANTS
%RACK_X = -1232.29
%RACK_Z = -69.92
%SAFE_Z = -5
%PROBE_X = -0.5
%PROBE_Y = -1200
%PROBE_Z = -7.5
%PROBE_DISTANCE = 150
%PROBE_FAST = 500
%PROBE_SLOW = 50
%T1_Y = -443.05
%T2_Y = -503.31
%T3_Y = -564.42
%T4_Y = -623.80
%T5_Y = -684.99
%T6_Y = -743.84
; INITIALIZE OUR ATC STATE
%global.atc = global.atc || {}
; GET CURRENT PHYSICAL TOOL
%currentTool = Number(global.atc.currentTool || 0)
; GET REQUESTED TOOL
%global.atc.requestedTool = requestedTool
; DEBUG
(msg, ATC M6 START)
(msg, ATC CURRENT TOOL = [currentTool])
(msg, ATC REQUESTED TOOL = [requestedTool])
; DETERMINE CURRENT TOOL RACK POSITION
%toolY = (currentTool == 1) ? T1_Y : ((currentTool == 2) ? T2_Y : ((currentTool == 3) ? T3_Y : ((currentTool == 4) ? T4_Y : ((currentTool == 5) ? T5_Y : ((currentTool == 6) ? T6_Y : 0)))))
; DETERMINE REQUESTED TOOL RACK POSITION
%requestedToolY = (requestedTool == 1) ? T1_Y : ((requestedTool == 2) ? T2_Y : ((requestedTool == 3) ? T3_Y : ((requestedTool == 4) ? T4_Y : ((requestedTool == 5) ? T5_Y : ((requestedTool == 6) ? T6_Y : 0)))))
; DEBUG RACK POSITIONS
(msg, ATC CURRENT RACK Y = [toolY])
(msg, ATC REQUESTED RACK Y = [requestedToolY])
; STOP SPINDLE
M5
G4 P0.5
; MACHINE COORDINATES
G21
G90
G53 G0 Z[SAFE_Z]
; PUT AWAY CURRENT TOOL
; If currentTool = 0, there is no known tool to put away.
[currentTool > 0 ? ‘G53 G0 X’ + RACK_X + ’ Y’ + toolY : ‘’]
[currentTool > 0 ? ‘G53 G0 Z’ + RACK_Z : ‘’]
[currentTool > 0 ? ‘G4 P0.5’ : ‘’]
[currentTool > 0 ? ‘G53 G0 Z’ + SAFE_Z : ‘’]
; PICK UP REQUESTED TOOL
G53 G0 X[RACK_X] Y[requestedToolY]
G53 G0 Z[RACK_Z]
G4 P3
G53 G0 Z[SAFE_Z]
; MOVE TO TOOL PROBE
G53 G0 X[PROBE_X] Y[PROBE_Y]
G53 G0 Z[PROBE_Z]
G4 P0.1
; PROBE TOOL
G91
G38.2 Z-[PROBE_DISTANCE] F[PROBE_FAST]
G0 Z2
G38.2 Z-5 F[PROBE_SLOW]
G4 P0.1
G90
; READ MEASURED MACHINE Z
%measuredZ = mposz
(msg, ATC MEASURED Z = [measuredZ])
; DETERMINE TOOL OFFSET
%hasReference = global.atc.hasReference || false
%toolOffset = (!hasReference) ? 0 : (measuredZ - global.atc.referenceZ)
; SAVE FIRST TOOL REFERENCE
%global.atc.referenceZ = (!hasReference) ? measuredZ : global.atc.referenceZ
%global.atc.hasReference = true
(msg, ATC TOOL OFFSET = [toolOffset])
; APPLY TOOL LENGTH OFFSET
G43.1 Z[toolOffset]
G4 P0.1
; UPDATE PHYSICAL TOOL STATE
; This is the ONLY place currentTool is changed.
%global.atc.currentTool = requestedTool
(msg, ATC CURRENT TOOL NOW = [global.atc.currentTool])
; RETURN TO JOB COORDINATE SYSTEM
G90
G53 G0 Z[SAFE_Z]
G54
G17
G21
G90
@ganfan This is WAY beyond my competence level. :grinning_face: Sienci monitors this forum category. I’m sure someone there will be able to sort this out.
The issue is that [tool] reads the currently active tool from the controller’s modal state, not the upcoming tool called by the T word—that’s why it’s always one step behind.
Try using [next_tool] instead:
%requestedTool = Number([next_tool])
(msg, ACTIVE: [tool] | REQUESTED: [next_tool])
Is there anywhere with all the different special words i can read up on?
thanks!
