Go To Corner shortcuts generate soft limit alarm code 2
Following my other post on using shortcuts, using the four Go To Corner shortcuts (Alt Ctrl 1, 7 ,9 ,3) generate alarm Code 2, soft limit. Using the icons on the GUI works fine.
Here is the console output from the two scenarios
error_with_move_to_corner_shortcut.txt (1.4 KB)
This should be fixed in 1.5.7, thanks for the report.
