Something new & concerning. gSender stops running in the middle of a job. gSender does not record last machine line ran. gSender does not loss XYZ postions. Any ideas on what is going on.
Get an Alarm 10: EStop asserted. Clear and reset (Emergency stop button was not pushed and did not need to be reset)
ran long jobs (2+ hours) last week - no issues (no changes to software, hardward or power)
gSender 1.6.4
Vcarve Pro 12.511
Sienci Longmill MK2.5
Laptop (gSender) connected to LongMill using ethernet cable
Update:
Had two(2) Alarm 10s ---- one @ about 70,000 code line and another @ about 141,000 —gSender is not keeping the code line it stopped at, I have to guess.
After the second Alarm 10 stop ---- (gSender kept XYZ postions at the right 0 value. I did not have to reset; XYZ or the carve file. gSender and the longmill carved for 82 minutes and about 159,000 machine lines to file completion without any additional issues.
@BMcNanley Before opening windows settings, can you tell me how you are physically connecting? That is, do you connect from your PC’s network card directly to the SLB or are you connecting through a network router/gateway?
@BMcNanley I just knew that it couldn’t be that easy.
Here is an older thread that seems to describe the same issue as yours. @Chucky_ott suggested a process to follow. Unfortunately, the OP of that thread never reported back on whether he found the issue. However, you may want to follow CO’s advice to look into the console to see if other errors are occurring before the number 10.
@BMcNanley If the file check consistently stops at the same location, there could be a problem with the g-code.
One user had a particularly long file which failed at the same location as per the file check. Turns out it was a precision error caused by using the imperial post processor (grbl-in) instead of metric. This was for a 3D carve with lists of fine movements.
Even if you design in imperial and display in imperial in gSender, it’s better to use the metric post processor. The conversions are done in the background.
I wonder if it might be static - which is a problem I had on a different machine. What type of material are you doing> Are you seeing a lot of dust clinging to parts of the machine? Also, any chance the Ethernet cable is an issue? Perhaps try a different one. Again I’d be happier if the cable was shielded (like a good quality USB )
