RobLM
November 8, 2025, 3:53pm
1
The alarms and errors page only goes up to 38!
Last week, it worked, I follow strict routines to start each session.
This week,
I type M61Q2 : the console says [msg:]
I type G65P203: the console shows an alarm: error:39 (Invalid gcode ID:39)
What gives? Restarting did not help.
Hi Rob,
The only mention of error 39 was in this topic. It might not be much, but at least someone else has seen it before. That’s always kinda reasuring.
I have the 48x48 altmill with the super long board EXT. I am trying to get the ATC to work but having a problem. I set the atc up and download the Macro to the sd card and installed it in my SLB. when I type in the manual command M61Q1 Iget a OK on my gsender 1.5.5. When I type in G65P231 to check my bit I get a error of Error 39 Invalid ID: 39. and the cnc machine will not run. I have set my ATC setting 4 different tttimes and the same thing. I don’t know if gsender is reading the sd card. …
Since it dkes not help much, it might be a thing to open a ticket. The siencitists might know more.
RobLM
November 9, 2025, 4:34pm
3
Thanks Spamming_Eddie, that is the problem. I have a Rapidchange ATC, and those G code commands pertain to it. I pulled and re-inserted the MicroSD card in the SLBEXT, and that fixed the software issue.
Now to harass the ATC guys about the hardware part of the problem. And to chase down the “Sciencitists” to let them off the hook.
