Error 2 bad number format when probing from xbox controler
Hi, so I manage to connect my xbox controller.
I map begin probing on the A button. I’m using the autoprobe. Longmill 2.5, gSender1.5.6
When I start the probe from the gSender interface, it works perfect but when I use the controller, the tool goes down and I get a message Error 2 bad number format.
Any advice?
@JMenard Welcome to the group!
Did you look at the console to see what input the controller produced? It’s just a shot in the dark but I’m wondering if maybe the controller button ‘fired’ more than once or something along those lines.
Comparing the console output from both ways of starting a probe might provide some insight into the issue.
EDIT: There might be a problem with shortcuts. Basing this on:
and
Those both mention Alarm 2. Did you get Alarm 2 or Error 2?
Thanks @_Michael I will check the console output this weekend and compare them. The message says Error 2
The fix for this will be part of 1.5.7, thanks for the report.
Thank you will wait for it then
@JMenard it came out today and should be fixed. My related issues have been.
Will update and test this weekend then
Just tested it works well thank you. However ran into a new problem. Will open another thread
